Interchangable Gaskets
Started by Redassassin, February 04, 2017, 08:08:56 PM
Are the bottom end gaskets (Specifically timing cover and sump) interchangable with the 1500cc and 1600cc? I.e. you can use 1500cc gaskets of this type on a 1600cc motor no problems, Cheers :)
Timing cover can be, but my 1600 and 1500 have different bolt patterns for the sump
All gaskets except Headgasket are interchangeable.
Cheers guys, ive brought the gaskets and if the sump gasket bolt pattern doesn't line up I'll just make new holes and put a thin layer of gasket seal over the original ones just to make sure it stays sealed
