Auto to manual
Started by Avenged Hunter, April 12, 2025, 08:01:10 AM
Avenged Hunter
Hi guys I've pulled the 1600 and auto box out of my avenger and put a 1500 with a 4spd in im regretting this now and wondering if the 4speed and the clutch will bolt up to the 1600.
Cheers, James
yep no change in architecture across the motor range as far as I know (eg I put a 1600 in a 1300 Manual car ; no issues)
in NZ you may get a wof fail & technically will need a cert (once you touch or mod the brake Pedal = virm fail)
"yes" it's been done & passed before multiple times & you'll be hard pressed for anyone to be able to tell the difference or that there is any indication is shouldn't be Manual <3
