Today, I bought a thing
Started by biltong_nz, December 17, 2016, 04:16:48 PM
biltong_nz
I paid an eye-watering $60 for this paper weight! Call it an impulse buy I guess.
I'm leaning towards it being a 1500 due to the LB stamp, and also a date stamped which is early 1973. Has double valve springs, apparently ran twin weber carbs before the car was crashed 20 years ago, and the engine was pulled out and placed in a shed where it has remained since.
Now I've just got the stock standard 1600 in mine, so what would be the best way to combine the two for more powerrrr. Assuming it has the high compression head then use that?
biltong_nz
Could this be an "S" ? Even though it looks like a 3 (sorry about the rotation of the photo). Maybe just a bit of the "S" has been chipped off?
Yep, that's the S head. What size valves has it got? Or have you not taken the head off yet?
biltong_nz
Head has seen better days...
Inlet valve around 38mm and exhaust valve around 33mm. Can't get them out as don't have a spring compressor
biltong_nz
Could this be a wider time chain cover? Can't get the bloody thing off though!
#6
The bolt post on the wide timing cover measure 25mm.
The "S" on my head has the same chip in the same place, but it looks like an S and not a 3
biltong_nz
Peek-a-boo
But I can't get this off  :'(
coulda stuffed a cylinder full of rope "if" the head was still on to lock it or something, gets harder to get that crank bolt out the more stuff you take off / out of a car
might need to take to for a drive to a garage or somewhere with a rattle gun
Any plans for the timing gears and camshaft? Need a set for the motor im building if you havnt got plans for those bits.
if you cant get the crankshaft pulley bolt off because it keeps turning, put the flywheel back on and use a large flat screwdriver jammed into the gear teeth and rest the tip of the screwdriver against egde of the block, this will stop the crankshaft from turning allowing you to undo the bolt
biltong_nz
Haven't got plans for anything else apart from the head, so for sure you can have those bits. However am still trying to get the crank bolt off - it's on there tight. So I'll let you know when I get them out. Drained the oil today, and for having sat for 20+ years, was in half decent condition.
Awesome, let me know what you want for them and a price for shipping to warkworth and I'll sort it out.
biltong_nz
Got the cam out. Part number 71981429. Quick search on here and there were no matching relevant part numbers. Is this normal or...?
On a side note, how do I get the lower timing gear off?  :D
Lower timing gear should just slide off when the pulleys been removed as it is just slipped over a keyway on the crank.
