Front Lower Ball Joint
Started by biltong_nz, September 13, 2016, 04:35:48 PM
biltong_nz
Anyone know where the best (cheapest) place to get a front left lower ball joint is? Mine has nearly had it and will definitely need one before next WOF.
Cheers
You have to replace the whole track control arm as the ball joint isn't separate. Try Graeme (Avengerparts) he may still have cheap Hillman ones left? If not I have a new one for $130 delivered.
avengerparts
Hi Billy, Only have the early [1970-77] lower ball-joints. Similar price each inc freight as Ross replied to you. Do have the later wide-track ones on order again ex UK but will be 6 weeks away.
biltong_nz
Yip just need one for the 74 Hillman - doesn't have the wider arms. Cheers
