WTB: Chrysler Avenger ignition barrel switch
Started by Redassassin, September 07, 2016, 09:35:27 AM
I've gone through 3 of these now (all second hand) and each one has carked it. Does anybody have a good condition one or know of a place I can get one brand new asap as my avenger is my daily driver, Cheers
care to elaborate the problem?
do you have a heavy bunch of keys on it or something? or is it the back end or the akey bit thats breaking?
might have a spare if you get stuck
Its the eletronic back end that is held in by a single phillips head screw on the ignition barrel. The first 2 were working fine but then would skip acc and on and you had to hold the key manually in an exact position to keep the car running. This one is now taking a few flicks to engage the starter motor
That may not be a switch fault..it could be the starter motor or connections to it.
To find out pull off the starter solenoid wire coming from the switch and put a test light or voltmeter on it to earth. Then get a friend to turn the ignition to the start position a few times..the light/voltmeter will register the current flow each time if the switch is good.
When I turn the key to attempt to engage the starter motor the rest of the electronics in the car "dip" i.e. show a loss of current that is usually attributed to sending power to the starter motor, but the starter motor doesn't turn until I've flicked it to that position again a few times. I was thinking about it and this seems very similar to the worn brushes I had on my old mk4 Cortina, Starter motor wouldn't engage on that until I gave it a few taps with a hard object. Only thing is I've just had this starter motor rebuilt about a month ago because the clutch fork inside it snapped and i'm pretty sure they said they did the brushes too, I'll give your solution a go though and see what happens, cheers for the help guys, sorry if i'm coming off a little abrupt, just a bit annoyed because its my daily
Whelp nevermind guys, I went to check over everything and the 12v terminal wire on the back of the ignition was nearly off, pushed it back up and its now starting perfectly fine, thanks anyway guys, crisis averted haha
