Measurements of rear gearbox seal?
Started by Redassassin, September 01, 2016, 09:48:46 AM
Needing a new rear gearbox seal as mine is leaking but the few places Ive rung say that I need to get measurements before they can match one up, does anybody have the measurements for the rear gearbox seal?
I have them, $30 delivered anywhere in NZ...PM me.
it might be written on the seal it will be two or three numbers internal diameter,outside diameter and thickness.
if you clean around it you should be able to read them.
Here ya go, ID- 34.9mm (1 3/8) OD- 55.85mm  Thickness- 9.34mm
