WTB: Chrysler starter motor
Started by Redassassin, June 20, 2016, 06:31:39 PM
Looking for a good starter motor for my Chrysler avenger with electronic ignition as the starter clutch return spring has broken on mine, Also looking for a crankshaft pully if anyone has one spare?
I saw that one on trademe but my starter motor appears to have more connections on the solenoid?
good spotting but no that wont make much of a difference
+ve & -ve feed, a feed to the coil & the signal from the Ignition switch are the basics there
(quite likely incorrect there but its pretty simple & there's no reason it wont work on your car wired up right)
We ended up taking my starter into the shop today and they're gonna fix it and put new brushes on for $155. Turns out the clutch fork is broken, thanks anyway though man :)
i should have a spare crank pulley,i should also have a spare fork for the starter if your rebuild place is having difficulty finding a replacement.somewhere......
pm yur details and i will dig them out of the black hole i store stuff
