wtd 1500/1600 short block double row timing chain.
Started by popadm, May 17, 2016, 07:26:31 PM
popadm
Wanted 1500/1600 short block with double row timing chain and gears any condition, need for rebuild for race car. located central north island, will travel to pick up .
Hi ,you can still buy double row chain and gears brand new, be a lot easier to find standard short block and convert it, not sure how easy it is to find the wider tension pad to suit, check out eBay as gears and chain are advertised there often, adjustable duplex gear is advertised at the moment, be great for your race engine.
