WTB : BW45 Inhibitor switch NZ ono
Started by JoKer, August 24, 2015, 09:24:59 PM
doing a bit of a makeover on the old girl
keen to get her legal beagle etc
Is this similar / made of Gold?
http://www.trademe.co.nz/motors/car-parts-accessories/ford/gear-boxes/auction-936332695.htm
Man that is pricey. I got one for the BW35 in my Charger ages ago.
I got it from Hemi Performance down it Nelson. I don't know if the BW35 and BW45 use the same inhibitor switch but it could be worth checking.
Not sure how much Hemi Performance NZ chargers but in Aussie they are $77
http://www.hemiperformance.com.au/store2/p_436_Borg-Warner-4-Pin-Inhibitor-Switch-Loom-Neutral-Safety
Or $55
http://www.pentastarparts.com.au/store/index.php?l=product_detail&p=900
cheer's, yea a mate here is into triumphs & they run 35's, he's gunna have dig in his shed first
thank you, rebuild of old switch is 1st test :P
edit : weird I cant view file on this system or pdf, will try at work tomorroe
renamed 'download' as a .pdf, worked :P
ILL
NO. DESCRIPTION YEARS QTY PART NO
ELECTRICAL COMPONENTS
NI Inhibitor Switch BW45..............................................1 A25700
Neat
TALK TO US NOW
NEW ZEALAND
P. 0800 658 899
E. info@atpnz.co.nz
www.atpnz.co.nz
AUSTRALIA
P. +64 2 4353 4712
E. info@atpnz.com
www.atpnz.com
I just rang, it would be a specail order, poor Rhys nearly fell off his stool too when I mentioned Avenger
$197 would be starting cost + freight
rebuild time (of old one) or scrounge off a BW55 (as ross mentioned 35 different & I note from the catalog 55's are lumped together
Hey Jared...Graeme (Avengerparts) has the BW45 inhibitor switch...drop him a line!
hi jared out of interest what was the bw55 fitted to? and what was the difference? we have a 35 here taken out of a hunter if you need bits it may go to scrap.
nah 35 are different, noted the 55 was on the same page/catalog posted above from atpnz.co.nz no idea where you would fine a 55 in real life
rebuilt my old one so good for now thanks guys :P
Bumpo
Switch is being a Dick : was ok for a WOF but not ideal only starting in Neutral currently
Will try Graeme too
sadly none in the Pasts I got from AZZA
internet link http://go4trans.com/transmission/bw45/bw45-electrical-parts-inhibitor-switch/
and another link
https://www.autozone.com/electrical-and-lighting/neutral-safety-switch
wonder if any of them could be made to work safely
Could always bypass the switch or fit an external one. Not ideal, but would work. Have you tried giving the switch a good clean?
yeah had the guts out at least once, & yeah external was next step, micro switch on the gear lever etc
Mine is bypassed and never checked during a wof check
