73' Avenger GLS...The build goes on!
Started by streetracer75, March 18, 2015, 04:15:05 AM
streetracer75
Latest addition to the build...Kenlowe HP 12" electric fan with stator blades.
This is a blower fan as I didn't have enough clearance (engine side) because of the water pump shaft.
streetracer75
Since I am upgrading the cooling system with the Kenlowe electric fan kit, I thought I may as well fit a set of silicone radiator hoses at the same time
streetracer75
I got this Superpro steering coupling doughnut to compliment the 2.5 quickrack. The quickrack is great with little or no road vibration already, but hopefully this will stiffen it up a little and improve things even further.
Also shown in the picture are a set of extra long track rods ends, as I am thinking about fitting adjustable TCA's to achieve negative camber.
kellarinpertti
Can I find somewhere silicone hoses that fit to Avenger well?
streetracer75
streetracer75
I decided to take off the cross-member and do the works strengthening modification.
These picture shows the gusset and box-section plates welded in.
streetracer75
#6
I also took the opportunity to take off and have all of the other front suspension components powder coated, while the suspension and front brakes are being rebuilt.
This picture also shows the longer (MK2) TCA. I am fitting these with an extra long threaded track-rod end to see if I can achieve more negative camber?
Next to go on are the GAZ coil over conversion.
streetracer75
#7
And now for the really good stuff...
Front coil-overs, with new lotus discs and callipers. Pads are EBC Yellow Stuff.
All fitted to the car and she now looks and sits sweet. I will post pictures of the car in the next day or two.
Scarlet
Scarlet
Hi Gary, this is how I cut the hole in the boot to clear the larger washers and bush
streetracer75
streetracer75
Hey Steve just one last thing. Is the domed extrusion just held in place with seam sealer or is it spot welded?
Gary
Scarlet
Hi Gary, no it is part of the square plate you can see welded to the boot floor, you will need a hole saw to cut it off
Eldon B
Please make a list of where you managed to find all of these awesome parts Cheers!
streetracer75
#14
Hey Steve please take a look at the picture and tell me if this is correct? The top bush and washer are sitting in hole and bolted to top plate, rather than sitting on boot floor?
