Wanted 1725 Engine
Started by Eldon B, November 08, 2014, 07:16:47 PM
Eldon B
Does any one know where i can get my hands on a 1725 to drop in my Chrysler Avenger, i have then engine out at moment (low compression)
That would be a backwards step Eldon. The 1725 Hunter motor is older technology and less powerful than the 1600 Avenger motor. It's also taller and probably won't fit anyway...plus it won't bolt onto the Avenger gearbox...you would need to use a Hunter gearbox too.
Best to put new rings and a GT cam in your Avenger motor to make a little flyer!
+1
There is an old post where that we discussed this and the Avenger engine is clearly better.
http://www.avenger.co.nz/forum/index.php?topic=386
Bigger isn't always better and even though the Hunter engine is bigger, it is old technology.
scott
hi  i want a 1725 engine for my 63 humber.Has anybody got one in good condition for sale?
Talbot
Hi Scott I can most likely find you one . What area are you ?
scott
#6
warkworth ph094222229 or 0211375023 thanks
