Twin Carbs
Started by the_customizer_91, July 21, 2013, 03:43:26 PM
the_customizer_91
Hello,
Ive got my temp engine all lined up and to give it a little bit of grunt id like to put the standard twin strongberg carb set up n it.
Does anyone have a set i can buy?
the carb i have atm is one off a Triumph so it doesn't run that great.
Cheers
Rego
She'll run even worse with twin carbs...it's just about impossible to find ones that aren't worn out!
Why don't you fit a 1.75" carby from a 3500 Rover V8?
They had two = 1750cc each, so the right jetting to give a 1600 Avenger more power.
Just need to modify your manifold flange (talk to azza1600) and it has heaps more grunt than a 1.5" carby, without the tuning hassles of twin carbs.
the_customizer_91
cheers that sounds great. ill see what i can find
