JoKer's '76 HN6783 Daily
Started by JoKer, June 05, 2012, 01:59:11 PM
Now sporting this Starter from my '72
yes thats got a 'remote' starter switch on it, like a Mini
only dumb thing is once it fires it disengages, so cold starting is a bit of a mish, ie might fire on 1 or 2 cylinders but not hold and die, starter disengages, so you literally have t re-try a couple of goes
needed gas and some kick-down fine tuning but is all go
to do list now includes
service good 20/50 oil
Axel pack (rear brakes leaking
and a cube of stop leak , saw at least one pinhole inradiator once it got warm
oldschool
Jared DO NOT use that inertia starter in your auto...it's the wrong type and will munt your ring gear...and it's own gear too!!
Your ring gear is designed for a pre-engaged starter (with the solenoid built in) that pushes the gear into mesh from the front and the ring gear has a front chamfer to lead the gear into mesh.
An inertia starter spins the gear into mesh from the rear, so needs a rear chamfer to lead the gear into mesh, in other words the ring gear is fitted the other way around.
I think James in Waipukurau would have a pre-engaged starter or plenty at Smash Palace. Hillman and Chrysler Avenger pre-engaged starters are the same.
chur : exact info I needed, the OEM starter should be back next week so no stress, it got me home and as I mentioned is a PITA to actually start the car
azza1600
so weres kierbears old one? as it was my spare! as my carb and electronic ign on her car, chicks!!!!
haha was having alternator issues i believe : and lights issues
Received my OEM starter back so in it goes!
How it looked with the (wrong) other starter in (from the brown '72 I have)
out
wanna see my ring?/gear
so all good now
some other points of concern
so yea a wof may be a wee way off on this
So I'm hunting one of these bolt/screw heads
lost one and kinda be nice to use the airbox once I get a round to WOF'ing this
last update over a year yeah!
I dont always take a picture when I get this out of the shed
I lie, dusted her off, & moved to a workshop for the rust/panel & paint & minor things HOPE to have legal and road going this month, If anyone has a deal on windscreen rubber (Front) I'm going to my local glass guy this week otherwise
TheMechanicnz
Did you ever find another Nut for the air box?  I've machined up a couple of new ones out of Stainless Steel if you need a spare. I'm assuming they all have the same thread pitch?
can do them knurled, slotted or both.
"It's better to enter a corner slow and come out fast than to go into a corner fast and come out dead"
yea man thanks for offer nice man who's name alludes me on here posted me a couple :P
I'm told the majority of the electrical foibles are remidied, all lights work, screen out next week hopefully
picked up some spare parts this weekend
am told there's more doors & windscreen/blocks/gearboxes in another shed, will gather as much as I can, if anyone spots anything in particular they need sing out
hoping to have WOF on HN before month is out
Upgradede time
unless anyone sees any issues? apparently the only option available is the new one on the right
, old light is on the left
Part #1055
& yes will be doing a pair not just the one, $80 each tho
I also need an inhibitor switch for a BW45 or compatible gearbag if anyone has any hookups? Think I lost mine in the swap
Rust, brakes, Hinges Lights all getting attention
Windscreen rubber & Vinyl re-glued too
In case anyone cares / reads these things here's the bill for the Front windscreen rubber
will be the same if you're an Esky fan, looks swish now I seen a bill for a windscreen too, not much change from $3k from the last member here who had one replaced via insurance
PROGRESS
Quote from: Madmax 2015=
all things chrome & shiney[/quote
paint fell on it & we spent today ticking things off the list
plus 40 this year cheep rego, i'm told about $26 per year, choooice
propper reveal to come :D
