JoKer's '76 HN6783 Daily
Started by JoKer, June 05, 2012, 01:59:11 PM
Discussion here : http://www.avenger.co.nz/forum/index.php?topic=426.new#new
Pre Summit : decide to have a wee tidy up of cabin area
remove dash/speedo, a few lights missing! was wondering where my High beam light was, glue auto gear indicator back together and fix light!
Lick of paint over the centre console, and tidy up of the upholstery on the dash, made pockets to fill gaps next to stereo out of screw containers, installed 12v Accessory (ciggy lighter) in blank above fan switch, more hot glue
Packed
and on way back
no majors, lost low beam again :/ having to hold in "hi flash" position to engage low beam, high beam is fine, frustrating
bout 280km on a tank/38 litres = 7.2 km/L (drag coefficient of the pedals lowering it a tad)
Discovered I have a light in the glove box (currently not working) a Working Steering wheel lock! I have to take key out proper to engage it, and the ignition is pretty flogged/can start with a screwdriver, not that they are highly secure in first place
aim to remedy that shortly (neighbour is locksmith or by other means)
13x7" Hotwires (have 205's on them = rub city, reckon if I chuck my 175;s all round they should work fine OR slicks for race car)
still having issues with lights specifically the contacts in behind the stalks for high and low beam, might resort to buying something new :/
Went and pillaged the blue/purple Alpine down at Wilfs for its indicator stalk
this the ciggy lighter thingy you were on about Rich? And moss on the windscreen might imply how ling its been there (willing to guess 20+ years given its location, moisture inside was evident on the hood lining from good frost this morning
Last part in the puzzle was this fuse hiding under the Valiant switch
my 'pockets' made from half a screw jar from Mitre10 (sans dash)
Went Manfield and had a heap of fun learning to drive My AUTO!
1,49's on the Yokohama's (rear, Enduro's front) and 1,44's on the Slicks, which as ya can see flat-spotted/wore out one good, which I blame for loosing a bolt holding the Air filter housing on, so I am searching for one of these big headed screws
also lost battery clamp out on track, was returned to me less one long bolt, Repco to the rescue, battery was resting on dipstick/dizzy when I opened bonnet
last thing I lost was the headlights coming back over the Saddle Road INTERESTING moment, was following a car so stayed close and bought new 30A fuse (se previous post) which I could access vis switch hole/pull dash out a bit...
Met ken who was piloting Neil's Cha''venger, Neil was in the Hump'mobile (also Hemi Charger powered)
oh and vids
http://www.youtube.com/watch?v=Wj9Ikzby9Yo
Bit of a Drift moment on road tires/last session of the day
Did 5 in total, all about 10 mins, 1st and last were on the Hotwires, bo brake fade, some over heating occured when I left the gear in "3" learnt to drive between that and "D"
used half a tant of 98 fuel, about 70 kms on track with my foot buried in the carpet
http://www.youtube.com/watch?v=8RZ4ar7xaf0
that's coming thru the "essses" and hairpin, only issues now are I reckon trans needs fluid change, as stick in something low and takes a bit of warming up to get to highway speed
1st turn of the track was notorious for me knocking it into "N" which was frustration too! (missed race seats heaps, other knee was on door for left turns)
Edit : top speed was 140kph on the straights via the Speedo (which I have verified with my GPS previously is correct on the Hotwires)
that's not right LOL
will change Trans fluid when I get a chance *knock on wood*
decided to try and bring it to work today : wont start! (to flush trans)
not even getting 1/4 throttle : feels like carbs are stuck? where do I look/grease first?
edit : kick down cable appears seized
smoking cables on cranking lead me to believe BAD earth, cause for stuck cable etc, will whip starter off (is recommended in Handbook for auto's) and grease shaft/fiddle with electrics etc
WTB: one of these screw caps!
Sorted Kick-down, still test driving to see if improvement with new fluids
replaced cork rocker cover seal at same time (pics later don't have cable on me)
New vs old Cork Rocker cover gasket, not sure if split was there before i tried to remove it, also notices a few spots where it had collapsed into the cover perhaps causing some leakage
exposed valve springs
Twin springs
Engine numbers
tidied up trans Sump
got a surprise to see all the patent numbers in their respective countries listed!
4 liters of new fluid in, seems to be running a tad low (Haynes bible says 6L capacity) seems to have improved drive-ability a tad, installing new kick-down was not fun as I dared not remove more than the sump cover and filter (not much access to the cable termination)
Quote from: JoKer on June 07, 2012, 07:06:43 PM
Someone Name the missing badge? Might find a "By Chrylser" to sit there
Gunna guess I could use one of these TC badges I spied
Quote from: avengertiger on August 11, 2012, 01:42:16 PM
Silver car totally just needs a Battery and a WOF
13x7 Hotwires to match HN will be shod in next set of slicks
needs a tad less tongue weight I think
only went from my house to work /1.1 km
has the right amount of LOW now thou!
sooo weird thing tonight : no reverse? bit of a clunking and rattle, hmmm
oh and <.< looks around shadily >.> read my wof sticker and it says the 8th month OOPS
best get that sorted eh, this could get interesting
also lost my pillar mounted aerial STINK can still get radio fine hence I didn't notice till today...
