JoKer's '76 HN6783 Daily
Started by JoKer, June 05, 2012, 01:59:11 PM
$52 for 12 months rego!
also swapped out the rear shocks as the ones in the car were not keeping the springs captive
which was weird because the top one (longer) have been in the car since I bought it & only seemed to be an issue after I swapped in the Chrysler diff, so nabbed the shocks from it as well, seems a great improvement straight away
Fresh WOF in time for Oldschool.co.nz Nationals next weekend
had the rear window seal 'cleaned up' and seems to be working great no leaks
front tires were out of round & did a job on the Steering 'box' so new set of tires (I haver a surprise to show you all but not just yet) a universal & Handbrake adjustment was required but we're all set for winter driving now!
OS Nats here we come! The weekend Starts NOW
Wof
New Tires
Wheel alignment & rides like a dream now!
OS Nat's 17 Completed
Kicked off Thursday night
another 400 Miles on the old girl mostly jaunting around the Waiarapa, gave the Gymkhana a miss at Masterton Motorplex but did manage an observation run down the strip
Came 4th in Rocker cover racing
Met up with Miles for that bit of trim
as usual had a blast with OS GC's
Went round the 'block' to Taupo on the weekend Dvk > Napier > Taupos > Turangi & back
should tick over tomorrow!
1 year a go I was waiting for tow truck with headgasket issues so got a idea of what how many KM's I've done in a year
8432KM lol or 5240 Miles
So then the Accelerator cable broke coming over the Saddle road FUN
bodged it up & made it hm Rung Graham aka avengerparts in Palmy
in Palmy & he had a couple in stock so I whip round get a cable
unfortunately not "quite" what i need with the setup I have (only the later Avengers had Cables) mine seems to have two 'ends' on the right on either end not the lil plastic bit so will pop in the motorbike sop tomorrow, least I have a spare in case I get stuck!
Just spoke to Graham & yep the earlier version I have with the adjusters on each end terminates under the Brake Booster so I'm going to try & bodge something up with the kit I have & a universal cable from the bike Shop, or rescue the OEM one from the spare blue car (looks pretty haggard)
failing that revert o mechanical somehow with the parts or pedals from the Cryslers or 1500 in my parts cars
can you not use your outer and get a new cable made up? are the adjusters on the outer?
Thats all i did when mine snapped, took it down to the local bike shop and they cut a new cable and slid it into the sleeve, then just silver soldered new ends onto the cable.
Quote from: JoKer on May 14, 2017, 09:08:41 PM
One of my throttle cables snapped a while back but I have 2 throttle cables so I keep driving like a bawse
#dualcables4life #redundantcable #backupcable
Quote from: JoKer on April 23, 2017, 09:27:14 PM
The Avenger dash looks quite a lot like a smaller version of the Charger dash.
Here is my Charger rolling over on Easter 2016
Nothing like a brand new 45 year old car with zero miles on the clock.
happy 5th Year Anniversary Baby!
Left old and leaky (thought fuel consumption was up) right old and not leaky
Instantly notice car starts without cranking, suspect all fuel was dissapearing back down the line
Gas dripping out of the body / crimped area looking at installing electronic ign this arvo too which I bought off 10-5's father
Bit cold here Last thurs
1.5 inches on the roof / 2" at a stretch of the white stuff
last time was 2011 and I was Driving this around :P
on slicks o-0
another Snow pic (out of focus hands were cold)
And put the Right Radiator cap on 10/70 vs what I was using 7/50
Part # CN1070 Tridon
also interesting to note the Paint 'falling off' my reconditioned Radiator, mind you it was fresh / still wet when I installed it before Driving to Leadfoot 2016
Non expansion Tank style (I have not tank) & the other was for a return system etc, might help with running temps (was on the cool side even without the Snow)
