JoKer's '76 HN6783 Daily
Started by JoKer, June 05, 2012, 01:59:11 PM
went for a hoon today with Feidling Hot-rod & Classic car club "3 degrees below" Run
won the raffle
have seen avenger short on Instagram reckon we might need something like that
source : https://www.instagram.com/p/BFcmAMdA4CK/?tagged=dodge1800
In for a wof, speedo had stopped working, here's the problem, lucky i had kept to original box &  2 seconds to retrieve a matching good one, are these similar on a manual box?
thinking ahead to next time, the colour is important apparently
The colour determines what ratio diff and gearbox you have in the car.
for example the 3.89:1 manual is white and the 3.89:1 auto is pink. The 4.375:1 manual is light green and the 4.375:1 auto is blue. That is from my 1250/1500 workshop manual, I have some later Haynes manuals if you need the colour for another ratio.
ahhh those fresh WOF Feels
https://www.instagram.com/p/BJrV-PXAcIu/
wasnt much of a chore this time!
place your bets now! that was a blast, not often you'll see both cars out at the same time
So this made a bad noise this week & resulted in a tow-truck ride, pulled diff cover off & it looks like this
with a wee bit of damage on the drive wheels, does anyone have any thoughts on the damage?, simpler to replace whole Diff & axels etc? Plan A was to just replace the diff itself
Bit the bullet & whipped the rear end out of the Brown Chrysler in the back yard, kept brakes intact & swapped over the axels too, recently had new bearings on one side
back on the road now
Stardate : 93880 kms on the clock (if it were 6 digits pretty sure its 193880
gained possession of these today
reckon can make them work on at least one Avenger....
www.instagram.com/p/BOD4V24A54C/?taken-by=akiwijoker
be the fook they are big lads aren't they
I measured 9 Inches HAH : orna'mental at the least, think I found one casing that might fit / hold air
this makes at least 3 pairs or widened steelies of various widths at my possesion....
had a bit of a play this Arvo, might need a bit of Guard rolling
Quote from: JoKer on December 19, 2016, 07:45:33 PM
Just a little bit :) You will be beating Kiera for biggest rolled guards on an Avenger.
got a tire for the other rim so may throw together a madmax Venger out of one of the spares :D
A madmax Avenger would be awesome.
There were quite a few Valiant Chargers in the Mad Max films.
This was from Mad Max 2
And this was from the new Mad Max film
And the mayor of bullet town was driving a tracked Valiant Charger
1000 miles (1654 Kilometers) and 13 days I am home after a "wee" road trip that went Dannevirke > Palmy > Turangi > Pokeno (icecream) > Auckland (Muesem & Airport)> Pukekohe > Hahei > Whitianga a couple of times > Taupo > Napier back to Norsewood & Dannevirke Home
Car never missed a beat & used no oil nor water that I can tell
great to put a few more internet names to faces & Volunteering  at Leadfoot was pretty cool
Highlight had to be BBQ & Beer up at Rod's "Mine-shaft" his private wine cellar & new House site
Last day on the Ranch looked like this after all the people had gone & all the chairs Umbrella's and banners had been picked up
www.instagram.com/akiwijoker
