Brakes
Started by Muzza, May 20, 2012, 09:42:33 PM
Muzza
Just striped the front brakes and the pistons are seized inside the caliper. Any ideas how to get them out.
compressed air? pressurise it somehow or tap the back of it with a soft / rubber hammer
Have just had seized brake pistons replaced in 2 of my Avengers, prick of a job...I got Autostop to do it!!
They soaked them in CRC overnight then used pliers to get them out, doesn't matter if you damage the pistons as they'll be munted anyway, new ones about $20 each, Graeme (Avengerparts) has them.
Muzza
Yeh I think I will get the professionals to look at them they are stuck solid.
Get your brakes working okay Muzza?
My avenger also had a sticking master cylinder piston, causing the brakes to drag...took it out and sanded it smooth, now fine again.
Dodge1500
Here when we got issues like this, we take the whole caliper to the brake repair shop, and in most of the cases they shift the broken or exhauts pieces like rubber seals or pistons, and they make them look good, like new ones. Other just spray some lubricant like WD40 on the pistons to make them move.
Cheers
Nicko
