Here's info on converting a Lucas Distributor to Electronic
Started by oldschool, January 29, 2011, 01:46:29 PM
Cheers yea I tucked 'er in the shed with a kick to sulk hah
glad I knew what it was straight away but not something that normally fails is it?
and landed from my local parts guy 2x PN CBR43's for under $30 (cheaper but same as the than the TM link
Looks like they'll do the trick & theory is I'll NEVER need the second one eh?
just ran the Multi meter over them
where as the manual is suggesting 0.5 and 5 ohm
will that be an issue? or have I got the wrong units ?
I can't read what the multimeter is saying, can you upload a bigger photo
the 'Specs from internet on the Part say 1.5 and 5 Ohm
Mulitimeter read 2 and 5 Ohms
My electical guy here says "yep it'll be fine, just run it
and all the searching on net I did earlier did not find any other options
#CBR41 exists but same specs
Fixed it : there was a Jumper 'missing" on the 1st 2 Terminals on the Ballast resistor (was never there) and mate was looking at the diagram & says : where's this wire
not sure why it became a problem after using it for a few years eh
