Starter motors
Started by blekkja, September 16, 2011, 05:10:54 PM
My car hasn't been starting recently: just making an annoying click. I've put in a NOS Solenoid and then cleaned up every single connection in the HT Circuit. Still no joy. Finally in a "you are going to start ya bastard" moment rolled it down the drive and almost jumped it. (Not much of a slope) However the starter is actually turning now, which is weird/nice. Unfortunately though it seems to have lost all it's teeth.
Before the Solenoid went (assuming it did - though it was overdue replacement anyway) I haven't really had any issue starting it, excepting the cold weather, and no indication that the teeth were on the way out. Is there something serious here or should I just replace the teeth and carry on? I did check the ring gear before I installed the Starter in the first place because it was also NOS (apparently; I have my suspicions) and I didn't want to fuck it.
I have an poked inertia-engaged unit lying about that has good teeth - am I going to be able to use these to replace the ones on my good motor? It is an older style one with a remote solenoid, btw.
The main reason for stripped teeth on a starter is a miss-match with the ring gear.
The ring gear has a 'lead-in' cut into the teeth to help the starter engage.
The same ring gear is used whether your Avenger has an inertia starter or a pre-engaged one, it's just fitted to match the particular type of starter.
The inertia starter needs the ring gear to be fitted with the lead-in facing the rear, while the pre-engaged type needs the lead-in facing the front.
So before you repair your starter, check which way the ring gear lead-in is facing?
If you look in the starter hole and there's no lead-in visible, that means it's on the rear and you need to use an inertia starter.
If you can see the lead-in through the starter hole, you'll need to use a pre-engaged starter.
Also check the ring gear teeth are all 100% okay at the same time, as even slight burring will wreck the starter pinion.
Aye its the same ring teeth around the flywheel, just have the chamfer, the shoulder facing the engine (pre-engaged) or the gearbox (inertia/bendix drive) I did one for a mini years ago. You have to put the new ring teeth in your oven for 30mins or so - just not too hot, the steel will become too soft if u heat it up too much. Put a bit of grease on the flywheels ring seat after you break off the old ring.
Then stuff as much driveshaft (the black CV boot grease) grease as u can into the starter's gear.
Happy a-startin'!
Damn. Motor is newer than the car and when I think back it would have originally had an inertia-engaged unit. Guess I will have a look tomorrow and hope for the best. I really don't want to have to take the engine out if I don't have to. (It's easy enough, but if it is out then I'm not putting back in until it's been completely done over)
Yeah I think they changed the starter type with the 1300/1600 motor upgrade in late 1973 (UK) early 1974 (NZ)
So your newer motor will need to use a pre-engaged starter.
Horopito Motors (Smash Palace) in Ohakune have some pre-engaged Avenger starter motors for sale.
You can also use a BLMC 1800 one...MGB, Marina, Princess, etc.
Just check the solenoid is offset towards the top, to clear the Avenger steering universal.
My motor is a 1500, I'm fairly certain. 1973. It def had a pre-engaged though - the Super is the only car I've had with the older style.
Is there any way I can check the numbers somewhere on the block and work out what year / etc the motor was made? The blocks are all essentially the same, right?
LOL...you might have a 1600 then??
I have a 1971 1500 and a 1974 1600 and the blocks look the same. The differences I've noticed are in the accessories:
The 1600 has a twin exhaust pipe manifold, the 1500 has a single
The 1600 has a Lucas 45D4 dizzy, the 1500 a 25D4
The 1600 has an all metal fuel pump, the 1500 has a glass bowl on top
The 1600 has plastic fan blades, the 1500 metal
The 1600 has a pre-engaged starter, the 1500 an inertia
Of course the accessories can be swapped over from block to block, so that's still not a 100% sure way of telling.
I guess if your motor has most of the 1600 parts listed, it's probably a 1600??
Don't think that will be much help: I've got a custom exhaust, electric fan and NOS Pump etc... everything that can be replaced has been. There is a chance the Dizzy is the one it came with - it is prob 6 years since I wrecked that car - so I will have a look. I've found that distributors are not very easily changed between engines for whatever reason - none of my old Hillman ones wanted to work with my Chrysler 1300...
I do remember messing around with Metal Fan Blades though... when changing Water Pumps. Um.
I might have to rip the head off and measure the cylinders to get any definite answer.
I think I've been getting confused to what starter is what. Anyway I have for whatever reason got a spare Pre-Engaged unit that works - just been out with a pair of jumper leads testing it - and the ring gear looks fine. I'll put it in tomorrow since it is starting to get dark.
