WTB: Avenger front brake rotors
Started by 1300super, June 25, 2011, 09:41:21 PM
Just need some New or used brake rotors in good cond. A friend of mine has put Avenger front brakes on his Humber.
Repco was a epic fail.... as usual with avenger parts. I call it FAILCO now lol. cheers.
Here's some new Escort ones on TradeMe...they shared the same Girling brakes back then I think.
http://www.trademe.co.nz/Browse/Listing.aspx?id=386015836
That's a generic picture, he sells lots of different discs and they all have the same picture...lol
Quote from: oldschool on June 26, 2011, 10:32:08 PM
I was about to say. I want some of those sweet vented rotors in my Avegner
so do escort 1s fit? im confused lol
Subarus have Nissan parts same as Hillman share Ford parts
its a cruel world, cant confirm these would work BUT wont be far off it
yeah i shamefully admit i have escort window rubbers, ross just knows how much i dislike escorts lol
Escorts and Avengers use the same brake pads and the same 4 x 108 stud pattern, so probably a good bet?
rs 2000 vented discs and m16 calipers are a popular upgrade in the uk,or 2.8 capri and princess 4 pot calipers are easy enough to do also.
Ford discs have different bolt holes so need machining and the disc is thicker so need to change caliper to P16s.
I use 2.8i Capri discs with p16 calipers (with sapcer kits), but fitted to Ford hubs, that also need a spacer on the stub axle to suite Ford oil seal and to get the correct caliper/disc alignment....and I needed to change wheel studs (When I bought the car it had ford wheels nuts on the frt and avenger on the back)
I mite ask my Grandfather in the UK to price me some up from Brown bros. Hopefully freight wont be too expensive
