removing avenger gaurds
Started by 2dooravenger, November 08, 2018, 09:45:34 AM
2dooravenger
Good Morning
i am trying not to fudge anything on this avenger i am working on but i can't seem to remove the gaurds and don't really want to start trying to pry them off the body if i have missed something.
i obviously have removed all the bolts and even the ones on the inside of the gaurd, the bottom of the gaurd is loose it just feels like it's glued on where the top line of bolts are by the bonnet.
anybody got any tips or tricks on how to remove without ruining them?
thanks Jesse
try a heat gun along the wing rail where you removed to bolts they do sometimes have an adhesive too along there but its non setting so will soften up and you can lift off guard,also i have come across one little spot weld off mig on the front panel before on the seam below the headlight just check along there too.
