TC cable pull and OEM filter pix for hunted
Started by JoKer, March 21, 2011, 07:01:22 PM
Top of Pedal - small bracket/hole for cable to be attached/run use steel split pin (something strong)
you can see side of the clutch pedal bracket/pivot
shares Hole in fire wall for my rear mounted water line (windscreen washer)
Mount holes for TC Filter Bracket
Aprox locations of filter housing
Flexi from bottom of the fibre-glass body to filter is an odd size which I dont have
