URGENTLY NEEDED Headlight Switch
Started by biltong_nz, August 08, 2017, 07:22:16 PM
Actually the one of these in my alpine is bypassed & I have a Valiant pull style switch
so its either dead too OR you can have it for swap old dead one
I'm not sure how I'd test it tho
biltong_nz
Haven't yet tested with a multimeter. How complicated would it be to just fit a 3 position toggle switch as sort of a temporary thing. Wiring diagrams are confusing haha
heh yeah I think you got the right idea & initially I thought it was the dip switch stalk having the issues
biltong_nz
Graeme's contacts haven't replied to any texts yet so not looking very promising and may have to work out a toggle switch :'(
are you "Sure" its that switch? ie its usually the Stalk that burns our hence my confusion
biltong_nz
Yep 100% the switch. Just did this dodgy hack job with a spare 2 pole toggle switch I had lying around. Worked a charm and lights are either on or off (no side lights) with the switch. Have to tidy it up tomorrow/make it as safe as possible.
Pics to follow later tonight
That switch looks much the same as my old mans triumph 2.5 aye, Being Lucas,  might be worth a try, more parts around for them than Avengers, Think Dad has a few floating around too
biltong_nz
My lights in a nutshell at the moment
Gangstar! Do you have a relay in the Headlight system? ie the switch and Stalk are a weakpoint with al lthe current going thru them
biltong_nz
Not the most appealing fix but it'll do for now! Don't think there's a relay in there - honestly lights aren't the brightest, so I guess all the current is going through switch and stalk.
The old Hillman Avengers don't have relays, all the current goes through the switch and stalk. The later Chrysler ones did have relays, they must have found out it was a weak point by then.
They fail all the time, I remember Ross lost his headlight switch when we were driving down to the Hawkes Bay Avenger meet up years ago. We stopped in a Horopito (Smash Palace) and picked up one on the way back home.
Did you find a replacement switch I wrecked one at the weekend and there happened to be a spare set of switches on the floor.pm me if need one still.
